fog light wires
hi just found 2 brown and brown/yellow wires (1 set either side)when i took my bumper off and wondered if these were fog light wires?no connections just wires.never had working foggies and it would be nice.many thanks
- E30 Zone Meets/Events Team
- Contact:
Have you got the insidefog switch and indicators on the instrument cluster, if so should be a simple job of hooking them up.Check your fuse box too.Not sure which rely it is but someone will be along, Mr Mooooore, and they should clarify whats what
- Brianmoooore
Wiring will all be there. Just add foglights, relay, fuses and dash warning light, and change the single foglight switch for the duel one.
