Drain Holes
SilverShadow
Hartge Crew
Mon Apr 20, 2009 1:46 pm
Does anyone know where the drain holes are in the hood compartment for a convertible.
Checked over the weekend and there is quite a lot of water there - so Im assuming the holes are blocked?
Mon Apr 20, 2009 1:54 pm
They are right at the bottom on each side, poke around with a metal wire or something similar and that should do the job. There is a pic on here somewhere, i shall have a look :)
Mon Apr 20, 2009 1:56 pm
Have way down this thread, some good info as well :) :cool:
http://www.e30zone.net/modules.php?name ... s&start=25
SilverShadow
Hartge Crew
Mon Apr 20, 2009 3:20 pm
Cheers Imy - Will give it a go tonight after work
Will a coat hanger do the trick or does it need to be thinner?
Chase007
Mon Apr 20, 2009 3:24 pm
This is a nightmare i cant see them Ahhhhhhhhhh :?
Mon Apr 20, 2009 3:25 pm
Coat hanger should be fine as long as it's not too thick :)
The water should drain out from under the sill near the doors. Also make sure these are not blocked as well.
Mon Apr 20, 2009 3:27 pm
Chase007 wrote:This is a nightmare i cant see them Ahhhhhhhhhh :?
Neither could I, I even used a torch but still very difficult to see. I just got the wire and poked it everywhere inside and it did the job :)
Pour some water in after to check to see if they have unblocked
Chase007
Tue Apr 21, 2009 3:11 am
If they get blocked do they overflow and you end up with water in your rear passenger footwells?
DaveD
E30Zone Wiki Specialist
Tue Apr 21, 2009 8:33 am
yes ...and also remember to check the exits in the sills just in front of the rear wheels....they can get blocked too
