Please help, I don't know how fast I'm going!!
adam3442
Post Mon Jul 18, 2005 10:10 am
My speedo packed up, any ideas on what it can be and how much it may cost to fix..
It's a 320i cab, I know it aint fast by any means but I would like to know how fast I am going
Many thanks in advance!
BrAdZ
Post Mon Jul 18, 2005 10:18 am
have you checked the fuses?
rowemeister
Post Mon Jul 18, 2005 11:09 am
I pressume the rev counter is still working. You may find the mpg meter and tachometer have also stopped working.
If so get round the back of the car and look under @ the diff. There is a 2 wire connecter plugged into the diff, this sensor is used for road speed etc, firstly check the wires to the plug has they corrode or break, if not buy a new sensor (not expensive). :wink:
325i Sport with Hartge H27 lump
Turbo-Brown
Boost Junkie
Post Mon Jul 18, 2005 1:34 pm
Yeah new sensor's about Ԛ£12 from the dealers (don't forget to ask for the O-ring to go with it)
If that doesn't work, it might be time to dig out the soldering iron and attack the insides of the speedo head. Only takes a couple of hours in all :)
adam3442
Post Mon Jul 18, 2005 3:47 pm
Cheers lads,
So far this was the cheepest repair my BM has had! It was simply a cable had come un plugged on the diff..
Cheers Peeps..
See you at the Ace Cafe!! :cool:
