Rear brake disk conversion
andrewpany2002
Wed Apr 15, 2009 2:37 am
Hi, im thinking of doing a rear brake disk conversion on my 320i and i know that the trailing arms need to be swapped. i just want to know if i need to use different drive shafts also ? will the 320i drive shafts fit in the new hubs ?
cheers
clarko74
Wed Apr 15, 2009 11:14 am
I was just about to say that they are all the same as I'm going to be doing this soon and was hoping my 320 shafts would fit straight in but I've just checked the part numbers and they appear to be different. Can anyone confirm this?
ABS ones are different to non-abs too I believe.
clarko74
andrewpany2002
Thu Apr 16, 2009 12:04 am
bump
Thu Apr 16, 2009 9:43 am
You wont have problems with drive shafts, they are interchangeable
andrewpany2002
Thu Apr 16, 2009 11:57 pm
ah that's good, cheers mate!
tomson
Fri Apr 17, 2009 12:42 pm
Drive shafts are all interchangeable as above the difference is some have the ABS trigger ring, some dont....
