Wheels rubbing inner arch
engine_ear
Tue Apr 14, 2009 5:59 pm
Running 14" bottle tops shod with 195/65 tyres, on full lock in either direction the tyre catches the inner arch. Specifically the plastic bit which seems to be part of the undertray that runs across the car in front of the engine. Also looks like the outer edge of the tyre may be catching the forward part of the inner arch, the plastic panel with hole for brake cooling.
Control arms are new, I can't feel any movement at the wheel, top mounts don't have any play I can feel. Any ideas? :)
1990 318i Touring
The red shed...
punk_sy
Tue Apr 14, 2009 6:49 pm
have you checked that its not the inner arch cracked and moved down onto the wheel?. have you lowered it lots ?
engine_ear
Fri Apr 17, 2009 8:29 pm
punk_sy wrote:have you checked that its not the inner arch cracked and moved down onto the wheel?. have you lowered it lots ?
Not lowered and inner arch is intact and in the right place.
1990 318i Touring
The red shed...
