Auto box problems (fixed)
chu346
Post Sun Jul 17, 2005 5:15 pm
I've just finished my 2.7 conversion and i can't go anywhere as the auto box won't select any gear.
Somebody help!!! :cry: :cry: :cry:
jamesroools
Post Sun Jul 17, 2005 6:50 pm
make sure you have the right amount of transmission fluid in the box
Image Image
chu346
Post Sun Jul 17, 2005 8:21 pm
Cheers dude i tried that.
Any other ideas guys?
MONSPORT42
Post Sun Jul 17, 2005 10:33 pm
Have you changed AFM or changed from Motronic? I had to abandon a change to MBE because it wouldn't talk to the gearbox. Check throttle position switch. Check connections from gearbox ECU and connection block on side of gearbox. Did you have gearbox out? If so, did you lock in the torque converter with geabox upright?
YOUR LEFT FOOT'S FOR BRAKING
stappin
Post Sun Jul 17, 2005 10:51 pm
Why have you fitted an Auto box I never understand why cars with powerful engines are fitted with an auto it's like choking the power output, wouldn't you rather make it a proper driving machine witha manual box?
MONSPORT42
Post Mon Jul 18, 2005 11:17 am
The majority of Motorsports came with the autobox in fact a manual one is very rare. The 2.7 conversion with the massive torque increase you get is a perfect match for the switchable auto. If you like autos, and lots of us do, this is probably the best car in the world. Have you tried a 2.7 auto with over 200 bhp and 220 torque? Seamless and awesome power.
chu346
Post Mon Jul 18, 2005 6:30 pm
stappin wrote:Why have you fitted an Auto box I never understand why cars with powerful engines are fitted with an auto it's like choking the power output, wouldn't you rather make it a proper driving machine witha manual box?
You don't know what your talking about, and it's clear to see that you don't know how to drive an auto otherwise you'd know that the only bad thing about them is a bit of a slow pull off. But once your moving it's sooooo much better!!!
What do you do when you just want to chill and just take it easy? Can you just put it in D and just cruise?
NO!
You have to p!$$ about with the gears all the time. Once you get converted to auto's mate you'll never go back!
MONSPORT42
Post Mon Jul 18, 2005 6:48 pm
the only bad thing about them is a bit of a slow pull off. But once your moving it's sooooo much better!![/quote]
Chu, when you get your's going, you won't be saying that!!!
chu346
Post Mon Jul 18, 2005 7:49 pm
I hope so mate.
chu346
Post Fri Jul 29, 2005 7:19 pm
I broke the oil pump.
So i got a garage to take the box out and then had to take it to another to get the new oil pump fitted Ԛ£188.
Gave the gearbox back to the garage and then started it tonight, but it's a no go. It seems to pop into gear for a moment, but there is just no drive.
I'm starting to get very pi$$ed :cry: :cry: :cry:
Any ideas guys?
MONSPORT42
Post Fri Jul 29, 2005 7:45 pm
Sorry to hear that mate. I made a comment earlier about fitting the torque converter to the box while the box is standing upright on its rear end. Thats the only way it will lock in properly. If this isn't done properly the result is usually a broken pump. Is your garage putting it together properly? Cos it sounds like its happened again.
chu346
Post Fri Jul 29, 2005 7:56 pm
I told them what to do when i took the box back to them. They have assured me they have done it correct.
It gotta be something else.
But..... if they have broke it i'll get them to get the box fixed again.
I'm just so disappointed as the engine just is so smooth and sounds so sweet, like my old e46 :drool:
Toby_Unna
Boost Junkie
Post Sat Jul 30, 2005 1:25 am
who diagnosed a broken oil pump u or the garage?
sorry chu don't know much about those boxes except they break a lot (had one in my m535i and had to remove it and put a manual in eventually).
you probably know anyway but they don't like the engine being reved when not in drive, burns the clutch packs out apparently because the oil pump's not being driven. did u do this when u got the engine running?
just wondering if the problem is something else.
thinking off the top of my head but can u check the oil pumps operation by removing the oil cooler lines to the radiator to see if fluid's being pumped when in drive and engine reved (rear wheels in the air)??
anyway well done getting that engine finished, was in lot of bits when i saw it at gsf!! if it's as good as an e46 then it's pretty good :cool:
fowler
Boost Junkie
Post Sat Jul 30, 2005 2:44 am
do the E 30' s have an inhibit switch on them to stop them going or something like that ?
just a guess.
I also though if box is pu in wrong the torque converter fcuks and you get no because it has no guts
just guess again ?
Regards Ben
chu346
Post Sat Jul 30, 2005 2:31 pm
Looks like the gear selector rod just needed adjusting and more fluid was required. Must have been some air in there.
As for driving it, all i can say is: WOW i've never been in a car which has been so smooth! and i've drove quite a few cars as i used to be a mechanic.
I couldn't be happier with how the engine has come out. :banana: :woohoo: :banana:
MONSPORT42
Post Sat Jul 30, 2005 3:21 pm
Good news Chu. Glad it's going for you. Now you know what I mean about a 2.7 auto!!!!
