Wheel spacer question
fastdiablo
Mon Apr 06, 2009 12:59 pm
I've got a big brake conversion so need spacers for the front wheels to clear the calipers. . . My question is do I need to put spacers on the rears to keep the front to rear track the same ? ? ? . . .
These are the spacers I'm looking to put on the front . . . these are 15mm but they also do a 20mm . . . If I put 15mm on the front and 20mm on the back what would this do to handling, would it make any improvement on just 15mm on the front or is it best to put 15mm front and rear ?
http://cgi.ebay.co.uk/15mm-Hubcentric-S ... 240%3A1318
Thanks :cool:
I reject your idea of reality and replace it with my own ;-) . . .
Ryans_white_one
Mon Apr 06, 2009 1:24 pm
not really no, if ur front wheels are wider than ur rear, it will make the rear end a tad unstable in the rain on roundabouts but it wont botjher ur tracking as there all still FACING the same way :D
fastdiablo
Mon Apr 06, 2009 1:43 pm
So hopefully nothing bad if I leave the rear track as standard ? . . .
hongkongfuey
Mad-tango-geezer
Mon Apr 06, 2009 8:39 pm
that looks like the set i bought for mine.
with cars like mine,
oze30
Mon Apr 06, 2009 9:31 pm
I'm going for these.
They're in Luton, so not too bad for us. Let me know if you want a set of 4 as I'll be heading there sometime this week possibly.
http://cgi.ebay.co.uk/Alloy-wheel-hub-s ... 240%3A1318
E30ToRing
Mon Apr 06, 2009 11:21 pm
I'd be interested to here how they compare. I was once advised that widening the front track relative to the rear would reduce understeer, and have yet to play with spacers. What brakes do you have?
leeparkes
Tue Apr 07, 2009 12:07 am
I recently brought a set of these and tbh they arent that good quality,they dont seen to fit snug over the hub and there is still vibration at speed,(not much but its there)
i would try the second set thats been posted.
if you put spacers on the rear no doubt it will catch the arches,you can either have the arches rolled or drop a size in tyre width,ie,205 down to 195
let us know how you get on with them.
fastdiablo
Tue Apr 07, 2009 3:30 am
oze30 wrote:I'm going for these.
Thanks for the offer to collect :D However I put the order in this afternoon, the company I got them through are based in Bridgewater ! . . .
Interesting that the ones you are looking at are 20mm. On these ones you bolt through the wheel and spacer to the hub, whereas the ones from the company I got mine from have the spacer bolting to the hub and the wheel bolting to the spacer (only on the 20mm spacers, the 15mm ones are normal) :?
Talking to the woman there it seems like they are the main dealer of this type. There is another company selling exactly the same product for about £8 more 8O
She seems to know what she's talking about and certainly knows what she has in stock. Had a little chat with her while getting the order processed and it turns out they are a garage that prepare rally cars and sell rally type stuff . . .
The brakes were already on the car when I got it, they are the Audi TT Disc/BMW750 Caliper combo. It had 10mm spacers on it but they didn't seem to be quite big enough to get proper clearance plus the standard spigot isn't long enough to protrude through the spacer to the wheel (thanks goes to Dave 318 for the idea to go looking for these :D )
fastdiablo
Tue Apr 07, 2009 3:41 am
Didn't see this till after I put the order in :roll: . . . Will see now how I get on with the ones I ordered . . .
The car has had 16 inch 225's on the rear at some stage and think the arches have already been rolled, but, if a wider front track reduces understeer then I will leave them as standard . . . Its an m30b35 so needs all the help it can get to get the front in winkeye
oze30
Tue Apr 07, 2009 11:24 am
Just ordered the same as you from bridgewater. 20mm will make the rears on mine et 15, but there's heaps of tuck at the moment, so it will work. If not, there's always Golf MK2 arches or major rolling flaring!
fastdiablo
Tue Apr 07, 2009 1:59 pm
oze30 wrote:Just ordered the same as you from bridgewater. 20mm will make the rears on mine et 15, but there's heaps of tuck at the moment, so it will work. If not, there's always Golf MK2 arches or major rolling flaring!
Why the change from the ones you posted ? . . .
oze30
Tue Apr 07, 2009 7:39 pm
20mm with longer bolts doesn't seem safe. Most other companies use the bolt to hub, bolt to wheel setup over 15mm (just researched this)
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0379882202
Should be better as they bolt onto the hubs.
