Brake pad worn lights
325360s
Post Fri Jul 15, 2005 3:46 pm
my brake pad worn light on my 90 325i sport has decided to take a mind of it's own this last couple of weeks even thought the pads r ok they come on sometimes when i hit bumps and other times they'll be there as soon as i turn the key. the brake fluid is spot on 2 anyone any ideas. :cry:
cheers
lenny
Jimbob
Post Fri Jul 15, 2005 3:54 pm
It could be the brake pad wear sensors playing up, about Ԛ£4 each and there's 2.
jonmsm
Post Fri Jul 15, 2005 4:01 pm
yeah, euro car parts supply the brake wear sensors, and they are very easy to replace, the pretty much just click in and out and then plug into the wiring loom by a very easy to seperate connector. If this doesnt do the trick you may have to trace the wiring form the connectors back into the engine bay. its possible that they have perished at one point and just needs patching which can happen with old rubber sheathed wires in hot places like the engine bay.
You will find the brake wear sensors are on the front passenger side caliper and the rear drivers side i believe.
Hope this helps :)
1986 e28 M535i (gone and missed)
1988 e30 320i cab (full resto STILL in progress)
1996 Volvo 850 T-5 estate (280bhp Turbo Nutter), T-5R (my precious)
1966 Fiat 850 saloon & 1970 Sport Coupe
C1 (go-kart)
Post Fri Jul 15, 2005 4:08 pm
"220 ohm reistor" .
See other current thread, or do search.
325360s
Post Fri Jul 15, 2005 4:09 pm
sensors in calipers r ok looks like i'm goin 2 have 2 get the multi meter :cursin:
325360s
Post Fri Jul 15, 2005 4:11 pm
wot u mean by 220 resistor
Post Fri Jul 15, 2005 5:54 pm
Look at the thread "brake pad warning light on dash" and follow the link mentioned in one of the replies. All will be explained!
