check control dipped beam illumintaed
Hap
Post Fri Jul 15, 2005 1:16 pm
my offside light at front is on its way out cos its ddmmer than the other side...i presume thats why the check control has picked it up? sorry to sound stupid but are dipped beams the normal headlights :hammer:
Hap :stupid:
rowemeister
Post Fri Jul 15, 2005 1:22 pm
yep. check all connections to lamp mate as the connection could have gone resistive which will lower the current to the bulb and it will be dimmer. :idea:
325i Sport with Hartge H27 lump
Hap
Post Fri Jul 15, 2005 1:38 pm
ok that sounds about right it still works but is loads dimmer than the normal light.
Where abouts should i look is it wires? or front of under the bonnet
Ps noTe your from Donny im from Scunny
Hap
rowemeister
Post Fri Jul 15, 2005 2:21 pm
cool a quick blast up the M180 (well if it were not for the bloody speed cameras).
That road was so good. :cry:
Check the connection of the bulb to its socket and also the connection of the plug to the head light unit. Look for corrosion on the sockets etc
Hap
Post Fri Jul 15, 2005 2:27 pm
might have to race you with my C2 Alpina lol
cool ill try nad look, its due a service next week so il tell them to have a look
rowemeister
Post Fri Jul 15, 2005 2:40 pm
sounds good.
Whats the spec on that engine?
Hap
Post Fri Jul 15, 2005 2:50 pm
not a techie but gasflowed head, 6 branch tublar manifold and exhaust, mahle pistons, alpina ecu 268 degree, the 2.7....its fast thats all i need to know
rowemeister
Post Fri Jul 15, 2005 3:12 pm
pretty similar spec to mine. :hump:
http://www.e30zone.co.uk/modules.php?na ... 7brent.htm
some things have changed a little.
Hap
Post Fri Jul 15, 2005 3:28 pm
mine is standard i note you have done alot on the air flow side of things
have to meet up sometime, Geeman is from Grimsby and a top bloke but he`s sold his sport :cry:
rowemeister
Post Fri Jul 15, 2005 3:32 pm
I took the M30 afm off mate. It was causing me headaches. I am now back to stock M20 afm. You need a custom map to run the large afm properly. I took the oil filter breather off too because it stunk. lol
I am going to go down the MAF route though and a custom map to get the full ponies from the engine.
A meet would be good at some point mate.
Hap
Post Fri Jul 15, 2005 4:24 pm
ps i see u have a DTM scorpion back box, i have a mint lemans 3" back box for sale if you may be interested
