Seems the caliper pins are worn, as the caliper rattles a bit, even though its all torqued up
Common problem ( search says no ) and will replacing the pins sort the problem, or does the carrier need replacing as well?
Matt
Although the carrier is fairly easy to cross thread.TOURINGDADDY wrote:just pins mate
