Hi got a 91 316i petrol is leaking from the tank from the hose underneath behind a cross member tried to tighten clip but still dripping the tank looks ok but there is rust where the pipe,connects to the tank.
is the tank knackered and if so how easy to replace help cos my misses is complaing of petrol smell in the house
									petrol leak
				sparky1972
Ah, women. They make the highs higher and the lows more frequent.
Friedrich Nietzsche
						Friedrich Nietzsche
				sparky1972
just had a nasty shock a new tank is £300 from bmw  looks like the girls goto to go cant afford that so if anyone wants a bmw 316i please pm me (sorry if this against zone rules )
Friedrich Nietzsche
						Friedrich Nietzsche
It will be gone like this one is
Don't go to BMW for a tank as you'll get reamed.sparky1972 wrote:just had a nasty shock a new tank is £300 from bmw looks like the girls goto to go cant afford that so if anyone wants a bmw 316i please pm me (sorry if this against zone rules )
GSF sell them for about £165 now, which is more expensive than they used to be (around £105 before)
				sparky1972
not had tank out but yep it looks like thats whats happened looking underneth to remove the tank theres the hose and several bolts and presto out comes the tank is that right and obviously the sensor any thing ive missed?
Friedrich Nietzsche
						Friedrich Nietzsche
- **BANNED**
Fitting a tank is time consuming rather than difficult,you need to remove the exhaust,heatshields,propshaft etc to get at the thing. Will be best to allow a day for the job if you are a non profesional mechanic.Tank it's self is held by five bolts accessed from under the car,there are also electrical and fuel pipe connections under the two hatches that hide under the rear seat base.Take care to note where pipes and wires go to make re-assembly easier. The tanks fail around the stub pipe where the fuel enters the tank,another leak point is the filler pipe down to the tank,be worth checking just where your leak is before commiting to a new tank.
									Youth is wasted on the young.
- **BANNED**
You will need to spend half a day removing and re-fitting the tank.It takes a very brave or foolish man to attempt a proper,welded repair to a petrol tank.You could try a Frost's 'petrol tank repair kit ' if you must,but after all the time,effort and swearing that goes into removing the bloody thing it just a'nt worth the effort.
				LeonNewton
i got a second hand tank of hear a few years back. worked a treat. think i have another spare that dont leek. pm me and ill get back to you after iv checked it out.
									Yer i am sorry for my bad spelling. i am dislexic and find it just as hard to read your posts as you do mine.
i have exactly the same problem! i though it was the rubber filler hose, but after seeing the pic of the rusty tank im now convinced!
i have a spare tank but its from a saloon. mine is a touring. will this fit??
