brake fluid
Wilson
What Brake fluid??
I will be completely replacing and bleeding my brake fluid in next couple weeks, I saw two different 5.1's silicone based and non silicone based!!! Whats the difference?
Also how much fluid do the 325's hold approx?
Marc
Marc
A1BMW325iSport
i use BMW brake fluid, it comes in a litre container which is plenty
rowemeister
"What Brake Fluid"
Is that a new magazine. lol.
I use BMW dot 4 in mine
325i Sport with Hartge H27 lump
Wilson
rowemeister wrote:Is that a new magazine. lol.
Wilson
Oh right, Dot 4...??
What does the DOT no. mean??
Templ8e30
Avoid silicone based brake fluid as our caliper and master cylinder seals aren't made for it and can leak, the silicone attacks the rubber and swells it causing leaks. Not good.
Either use a good quality dot 4 (standard brake fluid) or get a non-silicone dot 5.1
I've got ATE superblue ready to go in, It's a very high boiling point fluid compatible with dot 4 and it's a funky blue colour so you know when you've got all the old stuff out. Costs about Ԛ£18 a litre, used to be able to get it from ECP but they no longer stock it.
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
rowemeister
I think its the vicosity and temp range of the fluid.
Dot 4 is the normal one that most car manufactures use.
Dot 5 will run hotter before boiling etc
Wilson
I will prob use the non sil 5.1 then, but out of interest does anyone know where you get this superblue??? Would be handy to know when the old stuff is out!!!!Templ8e30 wrote:I've got ATE superblue ready to go in, It's a very high boiling point fluid compatible with dot 4 and it's a funky blue colour so you know when you've got all the old stuff out. Costs about Ԛ£18 a litre, used to be able to get it from ECP but they no longer stock it.
Cheers,
Iain T
rowemeister
If ECP dont sell it anymore try German French and swedish
Guest
Used to use Super Blue in my Evo 6 and have used it in everything else since, it's a good value/performance compromise. Tried to get some from ECP a couple of months back but didn't have any in, said they could get it next day though...have they stopped stocking it now?
I was told ATE Super Blue is what BMW use from the factory?
ATE also do the same fluid but in yellow, makes bleeding the system easy (it's called ATY 500 or something similar).
A good alternative is Motul RBF600 (think that's what it's called).
Wilson
Couldn't see it on GSF site!rowemeister wrote:If ECP dont sell it anymore try German French and swedish
Gwynleym10
i got superblue from wembley ECP about 2months ago, was under Ԛ£12. Its not on there website though, have to go and get it. They had loads there (5 palates!!) sure they couldn't have sold all of that!
Gwynleym10
Just noticed your in ipswich, ring up wembley to see if they will post it...
Wilson
thanks mate, will do in the morning
Guest
ECP don't post brake fluid (heard that before somewhere), they will get it in for you though if you ask for it.
Ask for either ATE Super Blue or ATE Racing Blue (they had it listed as Racing Blue down at Southampton).
Wilson
I heard that from someone else also!! I'm not gonna travel for it, i'm sure 5.1 will be sufficient for my journeys to work and back!!!325tracky wrote:ECP don't post brake fluid (heard that before somewhere), they will get it in for you though if you ask for it.
Gwynleym10
I could (probably..) get it for you and post it on if you wanted?
Wilson
That would be great, let me see if I can get it locally first tomorrow, then I'll let you know... Thank you v. much.Gwynleym10 wrote:I could (probably..) get it for you and post it on if you wanted?
I also got ATE suer blue dot 4 from ECP (Wembeley) about a month ago before i went to the 'ring. Gives a nice progressive pedal i find
AND IT WAS A TENNER FOR A LITRE TUB get in my son
Gwynleym10
Sounds about right, really can't remember..... Let me know as and when anyway WilsonAND IT WAS A TENNER FOR A LITRE TUB get in my son
Wilson
Will do... ThanksGwynleym10 wrote:Sounds about right, really can't remember..... Let me know as and when anyway Wilson
Guest
...and get me 3 litres of it while you are at it!!
Wilson,
Halfords do Castrol Response Super DOT 4, good specs and plenty good enough for the road.
Wilson,
Gwynleym10
I will if you want! You cot three cars? With brake fluid best is always best! Lots of people have recommended super blue....and get me 3 litres of it while you are at it!! Mad
Wilson,
