what is this?
petrol isnt showing empty.
only had this car a while so dont know if a light should come on when petrol is near empty.
im presuming the beep/chime is petrol level but not sure.
Also this car seems to be using quite a lot of petrol, more than normal at least, goin by the gauge. but im thinking i could have a petrol leak or maybe the gauge isnt working properly....
havent had long enough or driven for long enough to test it fully....
audible chime/beep when driving
construct_06
yes there is a fuel reserve light
i pressume you have a 13 button obc, becuase this will be what is making the audible chime, it bings when the temp is lower than a certain temp (3oc i think)
not sure if it makes a noise when the range gets low, i havn't yet fitted my obc
construct_06
cheers guys, that must be it. it was pretty cold alright over the last few days....
