vernier pulley setup
DORAS
Mon Mar 02, 2009 9:09 pm
Hi I built a 2.7 about 18months ago and just finally got around to fitting it , but i think i must have not set the timing correctly can someone tell me the best way to set this up with the motor in. I've skimmed the block and fitted schrick cam with vernier.
thanks
DORAS
Fri Mar 06, 2009 11:16 pm
someone must know?
325zimmer
Mon Mar 09, 2009 11:57 am
I got my Shrick Cam with vernier set up by the guys down at Bexley Motor works. They are probably worth a call.
All i can say is that he used a DTI guage to it set up.
e21Jason
Mon Mar 09, 2009 1:26 pm
Hi
You set them up on a rolling road, take a few power runs with different levels of advance.
Jason
Ant
Retired Team Member
Retired Team Member
Mon Mar 09, 2009 6:24 pm
easy fix to get you running
fit stock cam pulley , turn to TDC mark
ensure crank is also @ tdc.
Remove the stock pulley WITHOUT rotating the camshaft or crank
fit vernier with outer to inner bolts loose
fir cambelt and allow the tensioner to tension it all up, the outer of the cam pulley should rotate.
Tighten vernier and roatae the engine by hand to ensure valves miss pistons
Then go and play on a dyno, 1-2 degrees advance seems to work best.
DORAS
Wed Mar 11, 2009 10:56 pm
Thanks gents! Ant i got a chip of you months and months ago, Now have the car running and the rest of the car will soon be finished, Do you think it would be worthwhile me bringing the car up to you for fine tuning or do you think your programme would be o.k.? Its got eta crank, early 2.5 pistons, 284/272 cam, gas flowed head, lightened and balanced, full stainless and a 6 branch. If so any idea of cost?
cheers rich
Ant
Retired Team Member
Retired Team Member
Thu Mar 12, 2009 9:56 am
might need the throttle stop and TPS tweaked to get the idle smooth like butter, and we can tweka for part throttle low load mix, costs depend on time taken, no "parts" required :thumb:
get her sorted and gimme a shout if you have issues you cant resolve, the chip was specific to your spec , not a generic file.
DORAS
Thu Mar 12, 2009 6:32 pm
cheers ant i'll give you a shout when i get it on the road.
