immobilizer problem
- Brianmoooore
It's extremely easy, but depends entirely how and what it's connected to.
If it's connected as BMW intended, there's a two pin socket with a green wire to each pin hanging from the loom above the middle of the glovebox. The immobiliser should be plugged into this socket, so this plug is removed and relaced with a similar plug fitted with a short loop of green wire.
If the immobiliser is factory fitted, there should be a plug with loop tied to the loom nearby.
...or if it's like the toad one I removed 2 weeks ago from my car... scotchlocked(!!) in 3 places under the steering column and once by the coil... and they weren't even applied "properly".. if you can actually call scotchlocks "proper". Was a right mess and a while with the soldering iron to fix
Regards,
Ian
Regards,
Ian
Kingdoms are run by Kings, Dictatorships are run by Dictators, England must be a Country.
- Brianmoooore
Scotchlocks! I class that as good compared with some that I come across!!konfuzion wrote:...or if it's like the toad one I removed 2 weeks ago from my car... scotchlocked(!!) in 3 places under the steering column and once by the coil... and they weren't even applied "properly".. if you can actually call scotchlocks "proper". Was a right mess and a while with the soldering iron to fix
Regards,
Ian
Twisted together wires, insulated with a single wrap of cheap PVC tape is sadly not unusual.
Brianmoooore wrote:Scotchlocks! I class that as good compared with some that I come across!!
I'll hold my hands up and say I've done that in the past (years back when I was 17). It ultimately cost me a fire in my old Mk1 Fiesta, a re-loom job (not nicely split up into sections like the E30) and a bitch of a task to remove the foam the fire brigade sprayed everywhere in the engine bay.
Have long since learnt the error of my ways now.. hence the soldering iron to fix the mess that was under my dash (also included the remains of a Gemini alarm of some ilk).
Regards,
Ian
