clutch biting point very low
dmk_cars
Mon Feb 23, 2009 9:09 pm
sometimes the bitting point on my 325i sport is right on the floor and then other times its normal. I had an e36 m3 that done this also is it something to do with a pipe to the clutch or something??
leeparkes
Mon Feb 23, 2009 11:36 pm
Is it worse if you hold your foot on the clutch? ie,stop starting in traffic.
mrLEE30
Tue Feb 24, 2009 6:05 am
more likely something to do with a knackered slave and/or master cylinder, hence why it works on occaison, i will wager it works fine in the morning and progressively gets worse?? if so as i suggest, if not let us know
mrlee
dmk_cars
Tue Feb 24, 2009 7:43 pm
leeparkes wrote:Is it worse if you hold your foot on the clutch? ie,stop starting in traffic.
yeah it gets worse the more you press it only ever happens in traffic
retroroy
Tue Feb 24, 2009 7:47 pm
same thing just hapend to me on my 316 fitted new slave today £21.62 plus vat worked a treat
