knocking front suspension
bmben
Tue Feb 17, 2009 3:31 pm
recently ive noticed it, so i jacked up car and gave the wheel a wobble and it knocks (not a wheel bearing) with the steering lock on, theres a bit of left/right movement that you can feel. can also hear and feel it when driving along, mainly on crap roads around oxford...its annoying the hell out of me! just a case of worn mounts or bushes?
cheers guys
Ben
georob
Tue Feb 17, 2009 3:34 pm
Balljoint? Tie rod ends?
E34 x 1 - V8 + lots of CF
E30 x 2 - Tourings (1 x M50, 1 x M40)
RS6 C5 - Stage 1 remap - 500bhp
George
stonesie
Tue Feb 17, 2009 4:06 pm
It is most likley to be the bottom ball joint on one side thats worn, you need to have a look and confirm that it is this before you go ordering parts as new arms are around £50 each for decent after-market ones and near £90 for the genuine article, I would avoid the cheaper ones.
It is also worth having a good look at the rear bushes on the arms, these are about £22 the pair from the genuine parts section on here and an upgrade to the offset M3 bushes is a good move as theyre the same price, last longer and improve the feel of the steering, if you do these bushes then i would change both arms then you know it will be right for years to come :)
(This is what i have done to mine)
aj_mckay
Tue Feb 17, 2009 6:10 pm
Ah the good old sumpbreaker roads of Oxford, how I miss them. Not.
Another vote for inner ball joints from me - worth checking.
Mox3d
Tue Feb 17, 2009 11:38 pm
+1
Inner ball joints. If it tramlines like a sob then these and/or those pesky rear bushes.
...and I thought Norfolk roads were bad.
swinster
Wed Feb 18, 2009 9:44 am
Have a look at the top mounts of the front suspension, mine was similar this was the last thing I looked at after changing all of the rest. Doh...
bmben
Wed Feb 18, 2009 12:30 pm
Best get some proper tools out then!wait till the weekend :-( feels a bit unnerving driving it tho...nowt will fall off will it??? i'd be tempted by top mounts on suspension, jus cos its been lowered (when i bought it) and theres nothing in the history to suggest new top mounts, its had a few new bushes on front end, and by the looks of it the ARB bushes are shot to pieces - would that make nasty noises?
Ben
stonesie
Wed Feb 18, 2009 6:39 pm
Yeah the ARB links can make a bit of a racket but you would not feel it through the steering or by rocking the wheel so I don't think that's your main problem.
