Post
Fri Jul 08, 2005 9:04 pm
asked the same question, no. If you press the range button and then hold in the 1000 and 1 buttons it will tell you the amount of fuel left in the tank, when you fill the tank, there is a little black bung on the bottom left, pop that out and turn the screw, it only adjusts the amount a little but it sorted mine out.
