ignition switch and start button?
dannyg1
Fri Feb 13, 2009 6:39 pm
Hi All,
How easy is it to connect up an ignition switch and a start button? I will cof course remove the ignition barrel. I suppose that I will not need to use the key again?
Thanks.
zaust
Zone day release
Fri Feb 13, 2009 8:00 pm
you will need a couple of flipb switches too, but yeah easy.
M30 Tech 1 Touring on gas.
dannyg1
Fri Feb 13, 2009 8:03 pm
do u think that there will be a walk through of instructions any where?
zaust
Zone day release
Fri Feb 13, 2009 8:11 pm
No. Get a multi meter or power probe, and check which wires are going live at the different key position's.
Will be a good learning curve for you.
dannyg1
Fri Feb 13, 2009 8:15 pm
thanks! We'll if I do it, i'll let you know how much of a learning curve it is!
AdamAnt
Sun Feb 15, 2009 4:00 am
I've done it, and it took me a couple of hours, the longest part was the placement of the switches.
I've got 2 switches, one for accessory, one for ignition, and a button for the starter. i found a good diagram somewhere on teh web, try searching google images.
