can anyone help me source the rubbers for front calipers for a 325i
i am reconditioning them and need rubbers to finish.[/img]
need rubber
Sanchez
Templ8e30
They are still available from the main dealer for about Ԛ£10 per caliper, just refurbed mine a few weeks ago.
You need to know whether you have an ATE or girling caliper. The ATE has 2 removable sliding pins that need a 7mm allen key to remove the caliper from the carrier.
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
Sanchez
well i took them of a 320i Dreg E30, and gona put them on my 318i with some new drilled grooved vented babies, i undid the sliding bolts with a socket not allen key. i need the rubber for them and the rubber that goes round the piston.
did you just recon or swap?
cheers
cheers
