Gearbox. Is this good?
SwirlyE30
Post Fri Jul 08, 2005 12:35 pm
Just a simple one, but need to get an awnser quick!
I hoisted my IS engine up and power cleaned it all and used engine cleanerl. Making sure that i cover the TB and all electrics, intakes etc. I let it dry in the sun and went to lower it bakc down onto the garage floor and water (or what smelt like water and engine cleaner that i used) poored out a hole in the bottom of the gearbox.
Just a bit worried, the water couldnt have penetrated into the box could it? Im unsure if this is oil, or water, and eitherway if its fcked the box up. Sure was a good glass worth of water that came out
Anyone?
1986 Chevrolet Corvette. 330ftlb torque....V8s rule!
slideways
Post Fri Jul 08, 2005 12:48 pm
it was prob just water that got into the bell housing. not too familiar with the setup of the the bell house on the car but just as a precaution i'd check that the gearbox bolts are tight and there is no gap where the water could have got down 8O
Turbo-Brown
Boost Junkie
Post Fri Jul 08, 2005 1:38 pm
The bellhousings aren't really sealed, just have a splash / finger guard to stop shite from being pumped in there as you go along.
