Help with part number
Jonny_Boy
Wed Feb 11, 2009 5:02 pm
Can someone help me out with a part number. I need the switch/transistor for the blower. Its like a small, long black plastic box with holes down it and a coiled spring inside if you know what im talking about. Its for a 89 325i sport
BadDave
Wed Feb 11, 2009 5:31 pm
Here's the link to realoem.If you enter the vehicle details in there, you'll be able to look it up fella
http://www.realoem.com/bmw/select.do?vi ... E30&arch=0
HTH
Jonny_Boy
Thu Feb 12, 2009 5:14 pm
This is the part im looking. can someone even tell me what it actually is. Trying to get it ordered from bmw
badassyas
Thu Feb 12, 2009 10:52 pm
i wouldve called it a heater resistor and chose 64111370927 in my opinion. however the image looks nothing like it. ..
BadDave
Thu Feb 12, 2009 10:59 pm
It may be the dim/dip resister for the headlights
Thu Feb 12, 2009 11:04 pm
It's nothing to do with the headlamps.
Does this car have aircon?
Jonny_Boy
Thu Feb 12, 2009 11:26 pm
yeah its got air con
Thu Feb 12, 2009 11:35 pm
Factory fitted or dealer fitted? (Does it have a slatted grill at the front of the front centre console, where most E30's have a storage area?)
Jonny_Boy
Sat Feb 14, 2009 9:29 am
yeah its got the slatted grill
Sat Feb 14, 2009 9:49 am
It is the resistor that gives the different fan speeds for the heater/aircon motor, and since this is dealer fitted aircon (fitted after the car was built), entering the VIN into the ETK may not bring up the correct part number.
There was a thread a couple of weeks ago, where a member posted up a picture of this resistor that is apparently mounted on the front battery tray. Presumably, as part of the aircon fitting process into the heater box, the resistor (which normally lives just below the fan motor in pre facelift heaters), has to be evicted to make room for something else.
This resistor MAY be the same as the one that is fitted internally to pre facelift heater boxes, (it looks similar) or it may be a different part.
Ask Cotswold BMW, in our genuine parts forum.
