Brake Sensors?
squeaky184
I have just replaced the front and rear discs, pads & sensors on my E30 325i Touring. The light is still on the dash, brighter than everԚ…help! The light was flickering before I replaced everything and when I inspected the sensors before removing the old brakes etc, the sensors were broken off.(?)
Do a forum search for "220 ohm resistor" and my username.
Also check the sockets where the sensors plug in are clean with no corrosion.
OH, and welcombe to the zone. All you ever need to know about E30s is on here.
squeaky184
Cheers, I am asuming this is the post your refering toԚ…Inside the instrument cluster, near the top of the temperature gauge, you will see the soldered connections of a large 220 ohm resistor. There is a rectangular lump on the back of the cluster which accomodates this resistor. Resolder these joints and all will be well, as long as the plug / socket on the strut isn't corroded.
The plugs look ok as they have obviously had little use (clipped up out of the wayԚ—ahelpful eh!) I will check all wires leading to it anyway. Many thanks.[/quote]
