Car is Jerking (Stuttering) between 1900 - 3000rpm
fannyj
Post Fri Jul 08, 2005 8:26 am
Hi Guys,
My car seems to jerk round 2000rpm - 3000rpm, i replaced the feul pump, and had the AFM and ICV checked out - they are perfect.
What else do you think it can be?
Bob_S
Post Fri Jul 08, 2005 10:00 am
if it also has a lumpy idle it could be that a vacuum hose has come off, any slight increase in air in the engine will cause juddering and lumpy idle
fannyj
Post Fri Jul 08, 2005 10:12 am
Idle is rock steady... no lumpiness whatsoever.
hogweed
Post Sat Jul 09, 2005 11:02 pm
Most likely worn track on the AFM - 2-3000rpm is probably where it spent most of its life, thus the wear.
E30 custom active sub for sale - PM for details
