Hi All,
Right, getting into the new year now and it's time to sort out the track car - hasn't started since abingdon airfield late last year.
Reason - think it's that the flywheel key slot got dislodged. (think only pre-facelifts have this key slot for spark timing, later models do it differently)
Question - is there an appropriate stock flywheel from a different e30 that has the key slot but is a bit lighter?
Thought I might as well make the most of the opportunity, if not I'll swap like for like..
Thanks for any info!
Pre-facelift flywheel swap
Well i guess it would be easy enough to see what I have to swap if I had all the parts there ready. So there's an 'unused' place for the crank position senser to go somewhere on the front of the engine like on newer cars?
and how much would you want for said components??
I don't have the parts but for a loom, ecu, cps and bracket and then various different bits which have different connectors (oil pressure switch and oil level sender spring to mind) I think about £80-£100 would be about right. Might also be worth swapping the giant prefacelift starter motor to the smaller facelift type whilst you're doing all this (though not by any means necessary)
- Brianmoooore
The parts you want can all come from a 320, as long as you change the 'chip' in the ECU.
£80 - £100 should buy you all the bits you need, still attached to a 2 litre engine, still fitted to an E30.
Infinitely more simple job than changing the flywheel, and will give yo a better car than before, instead of just returning you to where you were!
