DEPO Angel Eye Installation
Daryll
Sun Feb 01, 2009 11:27 am
Gents,
After 3 months of not even touching my cab, I deceided to put my Depo angel eyes on. On side lights all the angel eyes light but so does the drivers side dipped beam ever so slightly. Then when I pull the light switch out to main beam, the passenger side doesn't light up at all but the drivers side does. Then on full beam again the same, the drivers side is ok, but nothing on the passenger side.
What have done wrong? I plugged the mains of the depo loom into the drivers side blug plug (car body harness). Should this instead plug into the passenger side?
Any advise would be most appreciated.
Thanks.
Daryll
@e30_daryll
zaust
Zone day release
Sun Feb 01, 2009 11:37 am
That is corect with the face lift, It will light the dipped as a side ligt.
M30 Tech 1 Touring on gas.
Daryll
Sun Feb 01, 2009 11:44 am
Hi Marc,
My cab is a pre facelift tho, plus I'm not getting anything on the passenger side at all other than the rings lighting up (no dipped/main or full beam).
@e30_daryll
zaust
Zone day release
Sun Feb 01, 2009 1:02 pm
Tbh mate I would not rather not say with out seeing it for real and probeing evrything.
Your welcome to pop round tomorrow afternoon if you want..
cliffybabe
Powered by Nelly
Powered by Nelly
Sun Feb 01, 2009 1:08 pm
Daryll, When i fitted mine from the top of my head i connected the loom that came with the lights into the drivers side and then run it along the front to the pass side
The loom supplied from the op of my head was jsut for the angel eye rings wanst it??
sati
Sun Feb 01, 2009 2:00 pm
normly the loom will plug in to the old bmw one , and on my facelift my dipped beams didnt light with side lights on , same goes for my mates pre face lift touring.
i will get a meter and check if your getting any voltage on the other side it as there might be a bad joint/break in the wire or it my be simple as a blown bulb
Daryll
Sun Feb 01, 2009 2:36 pm
Sati, I'll get the meter on it tomorrow and change all the bulbs or good measure too. Cheers.
Neil, Sounds like mines wired up the same as yours. The Depo loom has 3 plugs on it.
1 for the near side light 1 for the offside light and the other is the larger plug that plugs into th cars main harness. I'm sure it was plugged into the drivers side on my face lift as. Really annoying. I'll have a play tomorrow.
Hey Marc, thanks for the offer pal. If I get stuck I'll give you a shout. Hopefully I'll get snowed in at the house tomorrow and won't be able to go to work.
@e30_daryll
