1. The donor car is in bad shape but mechanically complete. So please let me know if i am on the right track. Both LHD if that makes any difference.
1. New clutch
2. New thrust bearing
3. Spigot bearing (any one got the part number or can explain what this is and why i would need it)
4. clutch master and slave cylinder seal/gasket kit
5. New gearshift bushing (its got a wobbly knob!!!) and the Z3 short shift bits.
6. Prop shaft donut thingies and centre bearing.
7. i plan on keeping the auto diff, but would i be correct in saying the ratio is different and auto is lower ratio i.e. more acceleration? And if mine is a real sport how can i tell if it is a LSD? Will i have any probs with auto diff?
8. now where you lot come in!!!!
what else do i need????
has anyone got a guide to perform the conversion? what ECU problems may i encounter, and what do i do with the inhibitor??
Any help would be much appriciated
mrlee
