brake help
lowdown
Wed Jan 14, 2009 9:10 pm
so iv had a few issues with juddering and brakes failing when braking hard,
i thought it might discs n pads but all seem fine
is there some sort of ABS sensor that could be faulty?
the problem only seems to be when the ABS should kick in ???
im a bmw n00b so dont be scared of talking to me like im an idiot:)
i do have car/engine knowledge tho :)
Daf318is
Thu Jan 15, 2009 3:42 pm
Just a thought - but you could eliminate the ABS by taking the relay out and seeing if it still judders.
When you say your brakes look fine have you checked the disks are not warped??
I had something like this on another car - strangely enough it was the steering rack :mad: after changing everything it wouldn't go - but when replacing the rack for different reasons the juddery braking dissapeared! :)
Now driving an E46 320D touring :(, but it get's worse..... the new project is going to be Ford powered!
lowdown
Thu Jan 15, 2009 6:27 pm
il havbe a look at the relay, if the discs are warped would i still get the judder under less heavy braking tho?
Oggy
Thu Jan 15, 2009 6:35 pm
From experience, that depends on how badly warped they are.
If you do a lot of braking from high speeds down to not a lot, or drive hard, left foot braking and such, you may find they're only warped badly enough to notice under heavy braking, on the other hand, they may be bad enough to notice at lower speeds and under more gentle braking.
Worth considering perhaps.
e301988325i
Thu Jan 15, 2009 7:13 pm
track rod ends shot is a possible cause.
I said:
e30topless said:
lock the wife in there
