how do i improve my cabby handling???
tinnaM42
Wed Jan 14, 2009 7:35 pm
just needs some tips on stiffining up my cabby.
thanks in advance.
Mahmood
Wed Jan 14, 2009 7:52 pm
lower it slighty, improve the springs/shocks and add a front strut brace.
tinnaM42
Wed Jan 14, 2009 7:54 pm
its on its arse already and alot of zoners think that a strut brace is for show. is there anything else i could do??
maxfield
Wed Jan 14, 2009 7:57 pm
A strut brace makes a massive difference.
Just cause it's on it's 'arse' don't mean it will handle well, if it's on standard shocks, they will probably be fucked.
Get some H&R ARB's and re bush it all the way round.
tinnaM42
Wed Jan 14, 2009 8:01 pm
its a spax set up all round.so your advise is to re bush maybe with poly bush's.
so apart from these few things theres not much more you can do???
gooner1
Out humping Reindeer
Wed Jan 14, 2009 8:02 pm
maxfield wrote:A strut brace makes a massive difference.
Just cause it's on it's 'arse' don't mean it will handle well, if it's on standard shocks, they will probably be ******.
Would,nt that depend on what strut brace Max.
You have,nt said what suspension etc, you are using already tinnaM42
tinnaM42
Wed Jan 14, 2009 8:05 pm
it's spax's all round and dropped 60mm on spax springs.
and whats the best strutbrace to go for?
maxfield
Wed Jan 14, 2009 8:07 pm
Sparco.
tinnaM42
Wed Jan 14, 2009 8:10 pm
right so thats about it for handling??
maxfield
Wed Jan 14, 2009 8:11 pm
Depends how much you want to spend.
You could buy coilovers, adjustable topmounts etc
1an
what tyres are you running aswell as this will make a mssive difference.
tinnaM42
Wed Jan 14, 2009 8:26 pm
its just on budget continentals. whats the best tyres to go for on a average budget?
1an
Wed Jan 14, 2009 8:29 pm
there ya go, no mattter how much moeny you throw at other parts you need to have decent tyres to get a car handling well.
tinnaM42
Wed Jan 14, 2009 8:32 pm
so whats the best rubber to go for????
maxfield
Michelin Pilot Cup Sport.
Assuming money's no object.
tinnaM42
Wed Jan 14, 2009 8:36 pm
maxfield are they road legal?
what are toyo r888 like heard good comments about them?
cliffybabe
Powered by Nelly
Powered by Nelly
Wed Jan 14, 2009 8:37 pm
TBH honest unless ur gonna track the cab i wont go for the roll bards, id go threw the bushs first all round front and rear top mounts etc
Get a strut brace
Look into new dampers and springs :cool:
tinnaM42
Wed Jan 14, 2009 8:41 pm
in your opinion whats the best strutbrace to go for cliffe
maxfield
Wed Jan 14, 2009 8:43 pm
Yes, they're road legal. Pilot cups are from what I've read better than R888's.
gudgeon
Wed Jan 14, 2009 8:44 pm
Weld a roof to it...
...just saying.
tinnaM42
Wed Jan 14, 2009 8:48 pm
they dont do the pilot cups for the standrd bbs 15"................................ well i cant find them if they do??
harry_p
Wed Jan 14, 2009 9:56 pm
While bushes and decent suspension will make it better it's still not a great base for an amazing handling car, the shell is just not stiff enough despite the weight adding strengthening that bmw added. Stet braces may help a little, but the main areas for flex will be the floorpan at it's thinnest point ( where the doors cut into the shape) and across he from bulkhead causing the famous scuttle shake. For this reason there's no point going too stiff with the suspension.
You could always weld a roof on, add a roll cage or weld the doors up :wink:
cheers,
harry
cliffybabe
Powered by Nelly
Powered by Nelly
Wed Jan 14, 2009 10:03 pm
tinnaM42 wrote:in your opinion whats the best strutbrace to go for cliffe
ive had a cheap one from ebay which made a good difference now im running a twin bar model with no joinging bolts and it feels even stiffer
sati
Thu Jan 15, 2009 12:26 am
how about anti roll bars? get the wheel's balenced and tracked.
markdemon
Thu Jan 15, 2009 2:00 pm
hi guys just looked on ebay for a brace and nuffin where else can i source one from??
thanx
Thu Jan 15, 2009 2:18 pm
the wanted section. :o:
oh errrm still not open,damn.
gooner1
Thu Jan 15, 2009 4:49 pm
May be wrong, but iirc, there was a post on here not long ago about a stiffening brace that ran from the rear of the car, and along it,s length. Not sure if it was cab specific,or even if they did one for cabs.
Was an American firm, i think. Realise that may be too extreme for you, but maybe worth a thought.
a_kara
Sun Jan 25, 2009 2:07 am
cliffybabe wrote:TBH honest unless ur gonna track the cab i wont go for the roll bards, id go threw the bushs first all round front and rear top mounts etc
Get a strut brace
roll bars are one way to improove the handling with out affecting the ride quality
i'd use the black bilsteins with some eibach springs and anti roll bars and strut brace
you'll have decent ride and it will corner much flatter.
60mm spax kit on cab is just wrong wrong and again wrong.
DaveD
E30Zone Wiki Specialist
Sun Jan 25, 2009 7:10 am
http://www.strutbracer.co.uk/page1.php? ... modelid=71
http://www.larkspeed.com/index.pl?p=03630SCv&a=i
and lots more
but the best way to improve handling is to fit m3 bushes....and make sure all the bushes are in top condition
