Just a random question really do car batteries get hot?
Does it effect them if they get too hot or does it not make the slightest bit of difference?
Do batteries get hot?
From a battery manufacturer
Temperature
Battery capacity is reduced as temperatures go down. This is why your car battery dies on a cold winter morning. Capacity is increased at temperatures over 25 C (77 F), but battery life is shortened. Battery capacity is reduced by 50% at -22 degrees F. Battery life is reduced at higher temperatures - for every 15 degrees F over 75, battery life is cut in half, for ANY type of Lead-Acid battery, whether sealed, gelled, etc
Batteries also get hot when charging and dis-charging, and yes careful charging is required to not overheat and damage a battery
Temperature
