Hesistant to run when cold
- FreddieS
My 320i doesnt seem to want to run nicely when cold, but as soon as it warms up it runs lovely (but does chuck out quite a bit of white smoke which i think is brake fluid
or maybe has a crack in the head letting water in, but doesnt seem to get thru any water!?) any idea what might be causing the rough cold running?
rebelcruiser
it aint rubbin it aint dubbin...
for sale honda civic pm 4 details...
most m20 engine's chuck out white steam when cold whats it like when warmed up ?
- FreddieS
Not as much, but when stopped for an amount of time it goes back to throwing out white smoke...e30topless wrote:most m20 engine's chuck out white steam when cold whats it like when warmed up ?
Thanks for the useful input.rebelcruiser wrote:but does chuck out quite a bit of white smoke which i think is brake fluid![]()
rebelcruiser
well mate i think its crazy that you think your car is chucking out brake fluid out the exhaustFreddieS wrote:Not as much, but when stopped for an amount of time it goes back to throwing out white smoke...e30topless wrote:most m20 engine's chuck out white steam when cold whats it like when warmed up ?
- FreddieS
rebelcruiser wrote:well mate i think its crazy that you think your car is chucking out brake fluid out the exhaustFreddieS wrote:Not as much, but when stopped for an amount of time it goes back to throwing out white smoke...e30topless wrote:most m20 engine's chuck out white steam when cold whats it like when warmed up ?
Thanks for the useful input.rebelcruiser wrote:![]()
well if it were to be going from the master cylinder into the servo, thus for thru the vac pipes into the inlet then it would be highly bloody possible.
When burnt, brake fluid emits white smoke.
if it was burning brake fluid I'd be worried this I doubt ....does it overheat when warmed up ?
rebelcruiser
never heard of that before
- FreddieS
No, temperature gauge never goes above half even in traffic when it was relatively warm. doesnt seem to use any water either as ive been checking it weekly to try to get to the bottom of this problem.e30topless wrote:if it was burning brake fluid I'd be worried this I doubt ....does it overheat when warmed up ?
