Rear bearing/Drive flange Torque setting?
wildeian
Sun Jan 04, 2009 11:44 pm
Is there a Torque setting for the nut that holds the drive flange on the drive shaft, and the bearing in place?
Haynes only has 5 series setting!!??
(325i Touring)
wildeian
Mon Jan 05, 2009 11:37 pm
Nobody?? :?
Can they be over-tightened?
ROC
Tue Jan 06, 2009 12:27 am
Wildeian, the rear hub/axle nut torque settings are 195 to 210 Nm (144 to 155 ft. lb.)
HTH,
Rich.
Barx325i
Tue Jan 06, 2009 3:22 pm
torque settings are for wimps :D
