Brianmoooore wrote:The extra pins in the C101 are for the oil level sensor, etc., and aren't relevant to your problem.
If the ignition lights weren't/aren't lit with the ignition switch on, then the problem isn't with the black/yellow wire.
It has to be a problem with the red wire (which comes from the fusebox), the ignition switch, or the plug and socket for the ignition switch loom, which should be clipped to the steering column, about half way down.
You will have disturbed things in this area when you fitted the engine ECU and it's loom.
oh right i see, ive checked all the wires underneath the steering column thery all seem to be fine couldnt find any damaged or chafed wires..
would it have anything to do with my imobiliser? i dont no whether its standard or not? i have a red light that flashes next to my heated rear screen switch.. doesnt look very standard... do you know where im likely to find my imobiliser??
