car stops reving @4000rpm and then pops
Wilson325i
Post Sun Jul 03, 2005 12:21 pm
please help figure this out :cry: ,
took the car out yesterday me and my bro, i don't usually lash my grears but i was giving it some, as i took of the lights 1stgear i always stop at 5000rpm (i never red line my car :nono: ) but when the car got to 4000revs, we nearly flew out the window :mad: coz i was not expecting it, then i took it to so deserted ind est and repeated it, the bloody car red lines when it feels like it. 3/5 the car redlined and the other two the car back fired with a pop :( plz help :?
stanley
Post Sun Jul 03, 2005 4:17 pm
take a look at the REV LIMITED piece in this forum sounds like the same problem.I'm having the same thing happen in my 316i :cry:
coldo
Post Sun Jul 03, 2005 5:00 pm
stanley wrote:take a look at the REV LIMITED piece in this forum sounds like the same problem.I'm having the same thing happen in my 316i :cry:
And me, had it checked by a couple of mates who know their shit, and none of them have a clue what it is. :cry:
Jordan
Post Sun Jul 03, 2005 5:06 pm
Had a similar problem with my e30. Found the cause to be a worn track in the AFM. The resistance material wears down over time and can create dead spots which really whack out the ECU.
Jordan
Raz316
Post Sun Jul 03, 2005 5:33 pm
Jordan:
so if it is that problem it's just a case of soldering along the two tracks?
If you're near Canterbury or newmarket and looking to sell your E30, let me know!
telski789
Post Sun Jul 03, 2005 6:12 pm
i reckon its the throttle sensor switch on the throttle housing,if it isnt set right or has become loose it wont make the signal for the second stage of fuel/air to come through so your foot is firm on the floor but the engine is starved so bang! you have to check for continuity (the little shockwave sign on the multimeter!) between the middle pin and the outer,the side nearest the windscreen and the middle should beep when the throttle is a gnats cock off the the stop,and the pin at the front of the car with the centre one should beep at around 80% open throttle,if it isnt coming in at all,then no beep and no fuel! these being set wrong are common reasons for flat spots too. maybe your sensor is just faulty.
Tel
Widge
Post Sun Jul 03, 2005 6:29 pm
Raz316 wrote:Jordan:
Na just give them a damn good clean with some contact cleaner, you'll probably be able to see the corrosion or dirt.
Raz316
Post Sun Jul 03, 2005 7:06 pm
Widge: Cheers, will do!
gareth
Post Sun Jul 03, 2005 7:11 pm
worn AFMs are a very common on the 205 gti (which also uses jetronic) and a good AFM clean up on them can work wonders. the contacts on the track itself can often be improved with a graphite pencil...!
Karan
Post Sun Jul 03, 2005 7:30 pm
what u actually should do is bend the arm slightly so it contacts a cleaner bit of track
Andy325i
Post Sun Jul 03, 2005 7:34 pm
Does yours only rev to 4000 rpm under load?
I'd put money on it that its an M40, if it is it will more than likely be the cam worn.
stanley
Post Sun Jul 03, 2005 9:07 pm
no lad it happens all the time
Andy325i
Post Sun Jul 03, 2005 11:54 pm
Still put money on it being the cam worn if its an M40 dude
Raz316
Post Sat Jul 09, 2005 2:09 pm
Back again,
I think it is something to do with the AFM because poking around with it while around 4000 revs does make a difference.
Contact cleaner has been mentioned, what exactly is it? I dont want to ruin anything ;)
irish320i
Post Mon Aug 01, 2005 9:56 pm
to check the trootle posistion sensor just disconnect it and try reving it it won t idle but its a quick way to check the fault
