Front Lower Wishbones
bastosm3
Tue Dec 30, 2008 6:28 pm
outer ball joints are knackered, do i
a) get entire wishbones and replace
b) get m3 alloy wishbones and replace
c) just buy ball joints and struggle to get the
old ones out of the old wishbones
whipsey
Tue Dec 30, 2008 6:34 pm
where abouts in northants are you mate? i have a press
stonesie
Tue Dec 30, 2008 6:37 pm
A) Theyre about £50 a side for decent quality ones, the cheap ones are a false economy because they will probably need changing again next year.
Add to that a pair of genuine offset M3 lower arm bushes (about £22 from the OEM parts section) to sharpen up the steering and once it's been tracked it will feel much better to drive 8)
fuzzy
He who sleeps with "Gingers"
Tue Dec 30, 2008 6:39 pm
how much are the main dealer arms?
stonesie
Tue Dec 30, 2008 6:43 pm
Put it this way, sit down before you ask... Especially if your after the alloy ones 8O
Edit
After a search i came up with £92.81 each for the steel arms, no price for the alloy ones and it would be worth re-checking the price as it was an old thread.
fuzzy
Tue Dec 30, 2008 6:45 pm
i remember the alloy ones being about £185 each or there abouts? but i cant remember if that was main dealer.
BadDave
Tue Dec 30, 2008 7:17 pm
fuzzy wrote:i remember the alloy ones being about £185 each or there abouts? but i cant remember if that was main dealer.
I think they've gone up to about £200 ish each now
New ball joints are about £6.50 Ea (inner & outer)and if you've got access to a press, it's much cheaper than new wishbones.
dannyboy759
Tue Dec 30, 2008 7:43 pm
Yeah alloy ones are 200 quid plus, not worth it although the ball joints last longer than the steel ones for some reason!
Could get group A stuff for that price!!
fuzzy
Tue Dec 30, 2008 7:46 pm
how much are steel arms from the main dealer? im guessing £70 ish?
stonesie
Tue Dec 30, 2008 7:57 pm
stonesie wrote: After a search i came up with £92.81 each for the steel arms, no price for the alloy ones and it would be worth re-checking the price as it was an old thread.
:wink:
fuzzy
Tue Dec 30, 2008 7:58 pm
id missed that edit... :D
Demlotcrew
Tue Dec 30, 2008 8:55 pm
dannyboy759 wrote:Yeah alloy ones are 200 quid plus, not worth it although the ball joints last longer than the steel ones for some reason!
They are heat treated, its impossible to change the ball joints in ali arms.
Andrew
Tue Dec 30, 2008 9:47 pm
The Alloy arms are £240+VAT from BMW now..
bastosm3
Wed Dec 31, 2008 11:46 am
i think i might take the balljoint route, i have use of a press, cheers for the help.
fuzzy
Wed Dec 31, 2008 11:52 am
do original bmw balljoints fit in ECP cheaper arms?
dannyboy759
Wed Dec 31, 2008 5:55 pm
BMW dont make balljoints for the standard E30 arms! you can only get them aftermarket which is strange as BMW makes then for the E36 for some reason the E30 ones where never designed to be changed! and the after maket ball joints from GSF ECP and so on dont last as long as an original BMW control arms!
bastosm3
Wed Dec 31, 2008 6:13 pm
what are the arms from GSF like ?
dannyboy759
Wed Dec 31, 2008 9:40 pm
Tobe honest if you go for the more expensive ones, theres usally a few options! they are made by Febi Bilstein and so on some of the same companies that supply BMW!
I had two for the front of my 325, i forget the make now but they were in the same sort of comparison to the OEM with regards to quality
fuzzy
Wed Dec 31, 2008 9:42 pm
i think the ECP version of the control arms i bought were about £35, theyve lasted a year so far...
