starter motor same on all 6 cyl?
sohood
Thu Dec 25, 2008 1:22 am
my starter motor has just packed up on 323i..
would one from another 6 cyl engine be a direct replacement?
Thu Dec 25, 2008 1:52 am
yes they are all the same as IIRC
town325i
Thu Dec 25, 2008 8:07 am
yes they are all the same i have one if you need one £30 posted
dips346
London Meets Main Man
Thu Dec 25, 2008 9:13 am
they do come in 2 sizes ,most early ones were bigger
sohood
Thu Dec 25, 2008 11:53 am
ive just tried to start the car this morning, after a few turns of the ignition it started up... but then after turning it off and trying again nothing would happen until like the 10th turn when it started up again..
im guessing it might not be a starter motor fault?? is there anyway to check if it is starter ot the actual ignition barrel without having to get under the car?
the car is a 1985 323i...
town325i
Thu Dec 25, 2008 3:58 pm
dips346 wrote:they do come in 2 sizes ,most early ones were bigger
its only the body that was a different size the cog that goes onto the ring gear is the same size
Thu Dec 25, 2008 4:43 pm
The next time it fails to start, use a piece of wire to short together the two appropriate pins in the diagnostic socket.
The starter motor should engage and turn the engine. This will determine whether the problem is with the motor or the starter circuit.
You will have the early D shaped diagnostic socket, and I think pins 11 and 14 are the ones you want.
sohood
Thu Dec 25, 2008 5:29 pm
ok cheers i will try that
Thu Dec 25, 2008 6:31 pm
or ark the starter with a good screwdriver,across both terminals.but make sure it's out of gear. then you'll know if it
grafts or not.the armature,or solenoid may have given up the chase. a smash on the ingrediient with a lump hammer may wake it up,,,,for a bit,.
dips346
Thu Dec 25, 2008 7:48 pm
yeah i know ,just saying that they is 2 sizes ,just in case he gets one and thinks its wrong
