starting problem ?
- lovettlovin
help needed asap i was driving my e30 when i turned the key off, and now when i go 2 start nothing happens but it trys 2 fire it i touch the termals on the battery quickley ? can anyone help ?
michealewk
mines just started doing this i thought it was the petrol any help would be grateful
- lovettlovin
no when the batter is conntected it wont start there is nothing not even a click from the starter motor but when i quickley tap the termals together on the battery it trys 2 turn over ?
michealewk
mine ok now it must have been the dodgey super i put into it
did you short the battery out or join the battery to the starter motor with a jump lead? I hope the latter...lovettlovin wrote:no when the batter is conntected it wont start there is nothing not even a click from the starter motor but when i quickley tap the termals together on the battery it trys 2 turn over ?
Try turning the ignition on, is there any dash lights? with the ignition on join the pins in the diagnostic connector that activate the starter (brian will know which ones).
