Lsd recognition
gomango
Mon Dec 22, 2008 2:24 pm
Could someone tell me if I have a Slipper on board(1990 325i SE),The tag says 3:73 and the numbers come up 9902,I have the Car up on Stands and both hubs are spinning round together so to speak,Thanks in advance.
Mon Dec 22, 2008 2:27 pm
If you turn one wheel and the other turns in the same direction then it's an LSD. If they turn in opposing directions, it's an open diff.
LSDs normally have an S on the tag prior to the ratio, e.g. S3,73.
leeparkes
Mon Dec 22, 2008 3:15 pm
Do a monumental wheelspin!
if you have 2 lines you have a slipper!
also do the checks maurice has pointed out.
gomango
Thanks :D
mrLEE30
Mon Dec 22, 2008 3:30 pm
or its welded...
but as he says it should read S3.75 9902 if its a LSD, just 3.75 9902 indicates a 3.75:1 ratio open diff
