Oil grade for 318iS LSD.
- tomstickland
I went to GSF today and they didn't have a clue what oil I should use, nor did APD. I called in at BMW and they said Castrol XJ. When I had the diff checked over the specialist said to use some grade of Valvoline. So just wondering what stuff to buy.
I believe it is Castrol SAF-XJ that you require.
Parts for sale - http://www.e30zone.net/modules.php?name ... 45#2733745
Ziggy
Castrol SAF-XJ or just 'LSD oil' if you're asking at the BMW parts desk.
You need 1.7L for a medium case diff, but I'm not sure on the small case!
- tomstickland
Ziggy
A good deal, as opie pretty much always are. Expect you'll need 2 bottles!tomstickland wrote:Thanks.
I did a google and found this:
http://www.opieoils.co.uk/p-736-castrol ... icant.aspx
- tomstickland
I also put my registration in here and it said to use the XJ
http://www.castrol.com/castrol/iframe.d ... Id=7044829
- tomstickland
Any idea where I can buy this on a Saturday morning?
Ziggy
Apparently this stuff'll work too... TBH I wouldn't bother skimping though! http://www.opieoils.co.uk/p-712-castrol ... r-oil.aspx
- tomstickland
I asked the man who reconditioned it and he said to use 75W-90 GL5 LS from any big name oil supplier.
APD sell it.
APD sell it.
I agree with Gussy, In the 4.1 I bought off him that he had refilled with B373, it felt fine but when I put in the Millers oil, It made lock far quicker it seems, Even with good tyres any bit of marginally loose or wet surface under foot while turning slowly or anything and the inside wheel would start to skip. One or two people thought it was welded
