Help!! More Power from my 320i convertible
Nikhil
Fri Dec 19, 2008 1:15 am
Hello people
ive got a 320i convertible which now looks the part, but it has no GO GO please help!!
any ideas dont really want to change the engine as the car has been looked after all its life, thats why i dont really want to change the engine.
any ideas would be a great help.
ive got a k&n and am thinking about getting a full exhaust system, well just waiting as i dont have £500 at the mo well thats the best ive seen them for.
so any one thats wants to sell, send PM's my way. :D
gcs325i
Fri Dec 19, 2008 1:39 am
In all seriousness a engine change to a 2.5 is the most economical way to more power, especially when you can pick an engine for £250-£300.
Upgrading the 320i is all pretty much explained here - http://www.e30zone.net/modules.php?name ... t=320i+bhp - taking note of Brianmoooore's quote. This should give you some more ideas anyway.
cro320
Fri Dec 19, 2008 2:29 am
build 2.7 :D
Bewdley320T
Fri Dec 19, 2008 2:38 am
I've got 325 manifolds and throttle body you can have FOC if you collect them. Makes a good first time improvement with the right chip.
swllt
Fri Dec 19, 2008 12:03 pm
To improve a 320i engine you need more air flow.
So -
1) Complete a full service and clean out air flow meter, in fact clean all the inlet system and seal any leaks
2) Flush thru' the injectors (redX or similar) and check the earths on the suspension turrets and the conector under
the inlet manifold
3) Mild chip from touchspeed or Ant (look in traders) I would recomend touchspeed at £30.00. but Ant does a fine
product and great service.
4) fit 325i throttle body with 320i modified inlet manifold to keep a resonable low torque. Don't fit a 325i manifold
unless you want all top end power and no pull low down. (see wiki for details)
5) I would fit an ajustable pressure regulator. but I know the 325i owners don't like them. They do however
improve a 320i with these mods. Site it back by the throttle cable bracket, Inlet side of the engine, and make
sure all the hoses and clips are in good condition
6) If you must fit a cone filter - build a heat shied. Best is a standard fillter box with a good free flow panel filter
then Drill your front grill in line with the air pick up pipe. 10mm holes are fine just where the bottom of the grill
fins are blanked off (you will understand when you look at the grill)
Do all this - It won't cost the earth and you will be amazed how good a 320i can be. (ask me how I know?)
cro320
Fri Dec 19, 2008 12:56 pm
how do you know? :D
this looks quite easy to do...mine B20 goes well, very well but I'm going to check all this stuff to be sure...
maybe K&N filter should make things better?
rebelcruiser
Fri Dec 19, 2008 1:02 pm
no unless its a panel filter :wink:
it aint rubbin it aint dubbin...
for sale honda civic pm 4 details...
Fri Dec 19, 2008 1:08 pm
+1
Fri Dec 19, 2008 6:33 pm
Mine was a 320 cab, def no guts til now winkeye I changed mine to a m30b35 engine, now theres no holding her back :mad:
fowler
Boost Junkie
Fri Dec 19, 2008 6:37 pm
Slap a turbo on it job done.
320 is pony engine
fit a M50 24v in it good replacement IMHO
EX A-Tech Workshop bitch !!!
gone but not forgotten
fuzzy
He who sleeps with "Gingers"
Fri Dec 19, 2008 6:44 pm
stick a decent 2 litre in and itll go like fook.
cro320
fowler wrote:Slap a turbo on it job done.
320 is pony engine
IMO M50 is not quite good engine as M20...
it's less reliable, more expensive to maintain, and lack of torque on low rpm's...
I took for a spin E34 525i M50 non-vanos, it's quite good after passing 4000rpm's but in town cruising, pretty poor without playing with lower gears and loads of rpm's...M20 is more powerfull from ''basement'' :wink:
Fri Dec 19, 2008 9:34 pm
fuzzy wrote:stick a decent 2 litre in and itll go like fook.
as long as its not a ford engine :P winkeye
Sat Dec 20, 2008 8:13 am
you will p1ss about for ages on a 320 trying to make it go like a 325. Quicker to source a good 325 lump and swap it over. No wiring issues, just plug and play.
Alpina99
Sat Dec 20, 2008 8:35 am
320 is pony engine
I'm quite surprised by this because I've got the M50 in the E34 & M20 in a 320 cab, I find that the more modern engine is better & I've never noticed a massive difference in torque.
As for reliability, I have had a couple of problems with the M50 but all were "DIY - able",
I know when the cab's finished it'll be having an M50 as well.
:D :D
Gone, but not forgotten !!
cliffybabe
Powered by Nelly
Powered by Nelly
Sat Dec 20, 2008 10:04 am
B7 wrote:you will p1ss about for ages on a 320 trying to make it go like a 325. Quicker to source a good 325 lump and swap it over. No wiring issues, just plug and play.
:thumb:
zaust
Zone day release
Sat Dec 20, 2008 10:19 am
↑↑↑↑ x2
M30 Tech 1 Touring on gas.
Nikhil
Sat Dec 20, 2008 1:08 pm
thanks everyone for your replys
just finished slamming my cab 60mm all round looks nutz (cant stop looking at it :D :D :D
really thinking about sticking some 9j's under there but dont no if thats asking for trouble.
iam still stuck as for what to do but the 2.5 lump is looking like the way forward.
cheers
cliffybabe
Powered by Nelly
Powered by Nelly
Sat Dec 20, 2008 1:10 pm
9s u say
:twisted:
Nikhil
Sat Dec 20, 2008 1:36 pm
looks sweet is that a 60mm drop to.
mine looks like its eaten a quarter of my rear wheel.
does it cause any probs
iam looking to get borbets A's on mine
chris_m50
Sat Dec 20, 2008 1:42 pm
9's :cool:
soon to be on a convertible!! winkeye
rebelcruiser
Sat Dec 20, 2008 3:58 pm
chris_m50 wrote:9's :cool:
that looks :cool:
how much has it been lowered.
Nikhil
Tue Dec 23, 2008 12:21 pm
looks sweets there the same ones i want on my cab :D 9j's all round.
any one got pics of the borbet on a cab slammed.
cheers
