putting new wings on??
dj
Post Mon Jan 24, 2005 12:27 pm
How much of a mission is it to change the wings?? Also does anyone know a good source for wings and a bonnet?
325i-sport
Post Mon Jan 24, 2005 2:46 pm
wings are Ԛ£20 quid each from gsf and take about twenty minutes to remove a side, if you have a non sport model. there are about 7 or 8 10mm bolts running parallel with the wing inside the bonet. there is 2 screws inside the arch holding the wing to the car. and lastly there is a 10mm bolt holding the front of the wing to the front valence, the bumper has to be removed to get to this iirc. remember to remove your side repeater and all mud guards from inside your arch.
as for a bonnet i have a 2nd hand one in dolphin grey no dents or rust and still has the sound deadning underneath. pm me if you want it. i also have 2 dolphin grey arches but for the money you may aswell get new ones
Post Tue Jan 25, 2005 1:17 am
Fit the wings with proper panel sealant between mating surfaces, or they will rust out in no time.
There are two small counersunk bolts with female hex heads at the front as well.
Beanie2
Post Tue Jan 25, 2005 9:11 pm
Are the GSF wings any good? anyone fitted one? Do they line up and fit OK and are they thinner, more prone to rust than the genuine BMW ones?
Post Tue Jan 25, 2005 10:44 pm
Haven't looked up their catalogue, but I expect GSF wings are pattern parts. Similar panels can be obtained from any good motor factors.
They will be less accurately made than genuine wings, and may be thinner steel, but how quickly they rust depends on how well they are painted, on on the use of panel sealant as I said above.
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Wed Jan 26, 2005 1:42 am
n00b alert! -- is that 20 painted from gsf?
325i-sport
Post Wed Jan 26, 2005 8:42 am
Ԛ£20 form gsf and they come matt black ready for primering
Guest
Post Wed Jan 26, 2005 11:55 am
Beanie2 wrote:Are the GSF wings any good? anyone fitted one? Do they line up and fit OK and are they thinner, more prone to rust than the genuine BMW ones?
I've a GSF wing fitted and i can't wait to replace it with an OEM wing, sounds different to the rest of the car when you give it a tap and it doesn't line up 100%:!:
Kedge
Post Wed Jan 26, 2005 6:29 pm
Going to be having my new wing sprayed and fitted in the next few weeks. It's a brand new from the dealers, will this still need this panel sealant(not heard of this before), do you think i should ask the bloke at the body shop to use it(if they don't use it anyway)?
Tried ordering a wing from ECP and GSF recently and both told me they couldn't get them, only did genuine wings at about Ԛ£50 more than the dealers!! 8O
Instagram - Kedge85
nwmlarge
Post Wed Jan 26, 2005 8:26 pm
this guide to fitting the wings is spot on i fitted one today and it was exactly as he said
aprt from my slam panel doesn't match up but thats a different story
