Glovebox, centre console and lower steering column shroud allready removed, plus disconnected wiring loom as required i think...... could'nt see how to get upper steering column shroud off, seems tight, plus do i have to remove instrument cluster first as well, have removed the 2 small screws, then got stuck here as well, what should i do now to remove cluster?
I have already removed 4 no 10mm bolts, 2 no on a bracket attached to each 'A' pillar and another 2 (1 underneath dash where glovebox should be, 1 under dash by steering column).
Dash now seems loose, what am i missing out, whats still connected?
Thanks in advance
