m3 track control bushes onto 325i sport
gingebmx
Mon Nov 17, 2008 12:22 pm
Hi guys
What are the advantages and disadvantages of fitting the eccentric track control bushes?
If anyone could explain the principal that would be great
I have done a search but there were loads of irrelevant posts and my eyes went square!
Chris
zimmerbimmer1
BMW Parts Meister
Mon Nov 17, 2008 1:12 pm
The wheels are moved slightly forward in the arch improving the turn in of the car for better handling as far as I am aware.
**BANNED**
Mon Nov 17, 2008 1:31 pm
Improve castor angle.The bushes are also solid,so they improve location.Turn in is improved as is steering 'feel'. Only downside is that the steering feels very slightly heavier.You may find that the front tyres rub on the front of the arch liner on full lock.Do it,well worth the effort.
Youth is wasted on the young.
gingebmx
Mon Nov 17, 2008 6:10 pm
Lovely thanks for that I will be doing them fairly soon as I have just ordered a press, yey!!!
bene30jane
Fri Nov 21, 2008 11:56 pm
maybe a silly question but what would happen if these are fitted with the off set hole 180 degrese out?.... also is there anyway of removing the bush from the arm and bracket to correct this?.... if need be i would cut the bracket to remove the bush from this.... any ideas?....
gingebmx
Sat Nov 22, 2008 10:47 am
Hi all, thats a good point I have the bushes and I assume the hole should be towards the outside of the car, which would push the wheel forward in the arch
Any help or tips much appreciated!
Chris
gingebmx
Mon Dec 15, 2008 12:58 pm
Got them on!
I did the ball joints and anti roll bar drop links and the front end feels amazing!
Really recommend the M3 bushes the car turns in so much better,
Pressing the ball joints in and out is not recommended though buy the whole arm(s) if you can!
cheecho
Mon Dec 15, 2008 6:45 pm
quality for hangin the ass end out too winkeye
turkey
Mon Dec 15, 2008 6:51 pm
its not that bad, just use a hefty vice! would'nt like to take them back out tho!
