gauges
player6
Post Mon Jun 27, 2005 8:43 pm
i want to add temperature gauge and oil pressure are thay easy to fit to my car
scot 328i with 260bhp
Post Mon Jun 27, 2005 9:02 pm
worth asking karan, he was fitting some auxhillary gauges in the centre air vents. Someone else was too, but can't remember who
A1BMW325iSport
Post Mon Jun 27, 2005 10:40 pm
oil pressure you could tap into the oil filter housing and put a sender in or replace the sump drain plug with a sender.
Matt
karlp
Post Mon Jun 27, 2005 11:18 pm
You cannot put an oil 'pressure' sender in the sump plug -oil temp maybe.
Best place is to remove the original oil pressure sender under the oil filter and replace with a 'tee' piece - attache gauge.
Karl
