Cheers for the reply Andy, yeah its from an auto.
That was welded using a 140A DC Arc welder, I prefer them to MiG as you have more current control (also have a scratch start TiG head for it)
The stand is 50*50 box 2mm thick, the plate is 6mm thick, same stuff on the crank lock.
I haven't cracked the nut yet, but I have a 36mm 3/4 drive socket and rachet for it, and a 12' cattle grid pole
Hoping that will be enough with a little heat.
As for what needs done: Going to replace oil pump, water pump, timing chain, fit a tensioner and replace the front pulley with a toothed one for use with the pulse sensor (rather than the 2 gearbox sensors) Will probably do as much to the engine as I can without actually taking the crank out, so all seals will be done. Also replacing the flywheel (of course).
I have a puller somewhere although it's not in very good shape, last time we used it we had a 4' bar with a centre mount on it and we were using that to turn the hub puller, needless to say we bent the puller somewhat...
what about using a slide hammer?
