Bleeding cooling system
stevew
Post Sat Jun 25, 2005 9:19 pm
Can i bleed my cooling system without using the bleed nipple on the thermostat as i can't undo this?
Is there any other way?
The bolt is locked solid and i don't want to round it off
btw the car is a bmw e30 325i sport
all help much appreciated
Steve W
Wilson
Post Sat Jun 25, 2005 9:49 pm
Mine is rounded.... I just use pliers to undo it... keep meaning to replace it, but not really a problem!!!
GDBN
Post Sun Jun 26, 2005 12:39 am
Just soak it in WD40 the night before and then have a go .... worked fine for me !!
Post Sun Jun 26, 2005 12:47 am
File two flats on the round section just beneath the screw head, and use a 8mm open ended spanner.
Wilson
Post Sun Jun 26, 2005 9:01 am
Brianmoooore wrote:File two flats on the round section just beneath the screw head, and use a 8mm open ended spanner.
good idea!!
Post Sun Jun 26, 2005 10:08 am
I've done this as a matter of course to every 6 pot E30 that's come my way, and once done, have never had any trouble loosening the bleed screw.
The original screw seems toi have a hex head which tapers slightly towards the top.
320Touring
Post Sun Jun 26, 2005 1:18 pm
stevew wrote:Can i bleed my cooling system without using the bleed nipple on the thermostat as i can't undo this?
Steve W
if you park the car with the wheel nearest the expansion tank up on a kerb, then it becomes the highest point on the system.
if you leave the cap off, it should bleed it.
best to try the 2 flasts technique described by brian first tho... :cool:
