e30 lsd
SHAKEELE30
Boost Junkie
Post Sat Jun 25, 2005 5:00 pm
hi, just lookin for a lsd for my car and wanted to know what different ones there are out there and which one is better, which ratio etc. Will this make any difference in performance to the car. And how much do they go for? cheers
Toby_Unna
Boost Junkie
Post Sat Jun 25, 2005 6:01 pm
depends what car you have as to which one's best.
facelift 325i sports used a 3.91:1 ratio which is quite low geared (good acceleration but high revs on motorway)
the lower the number the longer geared your car will be. so if you put a 3.64:1 ratio diff on you'll get less punchy acceleration but more comfortable cruising.
think those two are the most common ratios available, both good on a 325i but don't know about lesser e30s!
billgatese30
Post Sat Jun 25, 2005 6:03 pm
Toby_Unna wrote:think those two are the most common ratios available, both good on a 352i but don't know about lesser e30s!
352i...........fook that would be cool :cool:
Toby_Unna
Boost Junkie
Post Sat Jun 25, 2005 6:04 pm
:hammer: got to aim high though
i'd already edited it when i saw your post, otherwise i'd have left it!
billgatese30
Post Sat Jun 25, 2005 6:09 pm
change it back.........352i would rock
Toby_Unna
Boost Junkie
Post Sat Jun 25, 2005 6:13 pm
a gently bored 750iL motor might do it! :offtopic:
