HELP! Where are the rear handbrake cables held?
Project_E30
Post Sat Jun 25, 2005 1:33 pm
I have changed my rear drums to discs. I bought new hand brake cables. However I cannot see how they are held in place to stop them colliding with driveshafts etc.
Does anyone have any pics of their handbrake cables so I can see how they are held in place?
Post Sat Jun 25, 2005 1:39 pm
Thet fit into clips on the suspension arms, but they shouldn't come any where near the driveshafts if they're not in the (often broken) clips.
Project_E30
Post Sat Jun 25, 2005 7:20 pm
Brianmoooore wrote:Thet fit into clips on the suspension arms, but they shouldn't come any where near the driveshafts if they're not in the (often broken) clips.
Unless I'm being thick I cannot see any clips?
Can someone please show me where these clips are supposed to be and what they look like!
Many thanks
jonbuoy
Post Sat Jun 25, 2005 8:32 pm
Not dead on sure but if u have'nt changed the arms aswell then the clips won't be there. Have'nt got a pic for ya sorry mate but that is my theory :D
Sjoerd320i
Post Sat Jun 25, 2005 8:35 pm
:offtopic: thats one huge sig mate :wink: need someone to resize it for ya?
sorry, can't be of any help on the cable's tho
Templ8e30
Post Sat Jun 25, 2005 9:29 pm
I wrote an article on the conversion last year, Here's a pic:
The white clips are attached to the anti-roll bar mountings on each trailing arm and are notoriously brittle.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
dazleeds
old skool raver
old skool raver
Post Sat Jun 25, 2005 9:40 pm
yep thats em
iain hows it goin mate /? u get brakes etc done?
painted manifold , tb and rocker cover tday looks :cool:
www.oldskoolfantasy.co.uk
Templ8e30
Post Sun Jun 26, 2005 12:24 pm
Hi Daz, not bad mate. Got the braided hoses done, finished about 8.50pm that night !.
To get the hoses that run over the subframe I cracked them loose with spanners then cut the rubber off leaving the crimp end then used a deep 14mm socket to unscrew it. Much easier than fiddling with 1/16 turn at a time with spanners !.
Feels much better, need some ATE superblue for the trip to the 'ring 8)
Glad the manifold is ok for you :D
Back on topic :wink:
Cheers,
Iain T
Project_E30
Post Sun Jun 26, 2005 2:19 pm
Templ8e30 wrote:I wrote an article on the conversion last year, Here's a pic:
Cheers,
Iain T
Does anyone have a part number for the little brittle white things then. As my trailing arms didn't have them fitted.
Please help!!
dazleeds
old skool raver
old skool raver
Post Sun Jun 26, 2005 11:18 pm
buy some rubber coated p clips mate
much easier and dnt break
shame i didnt know when i came over got loads p clips here
Daz
ps whate the chopped and possibly stretched saxo in your area all about???
Templ8e30
Post Mon Jun 27, 2005 12:36 pm
The ETK shows the following part numbers :
Bracket : 34 41 1 153 880
Tubing support : 34 41 1 154 158
You'll need 2 of each.
The bracket acts as a washer between the anti-roll bar bracket and the drop link bolt.
Need to buy some replacements myself as one is held on with a cable tie :? not sure the MOT man will be too happy about that.
Cheers,
Iain T
Post Mon Jun 27, 2005 1:44 pm
It's just the retaining part of the clip that breaks normaly.
The use of a correctly sized cable tie to retain the cable in the cradle of the clip is perfectly acceptable.
