obs wiring help
danman2k
Thu Oct 23, 2008 5:48 pm
hi, does anyone have a pic of where i put the temp sensor please. also would be helpful for help on wiring through the bulkhead into the interior to connect it up, i am having trouble with these bits only. many thanks
Thu Oct 23, 2008 9:21 pm
Location of temp sensor depends on facelift/pre facelift.
Wiring to the sensor is a blue wire and a brown wire, and the loom goes through the grommet under the fusebox.
danman2k
Thu Oct 23, 2008 9:28 pm
Brianmoooore wrote:Location of temp sensor depends on facelift/pre facelift.
i do apologise, its a facelift 88 325i.
many thanks, i will have a good second look on lunch tomorrow when light. :D
ha22
Thu Oct 23, 2008 9:31 pm
The sensor goes in the passenger side brake duct, from the top, theres a locating place for it.
SPADGE
Thu Oct 23, 2008 9:48 pm
ha22 wrote:The sensor goes in the passenger side brake duct, from the top, theres a locating place for it.
Only on facelift cars
danman2k
Thu Oct 23, 2008 9:49 pm
i think i found a useful pic, is this correct?.
i dont think i saw the clip when i looked earlier under car.
Thu Oct 23, 2008 10:13 pm
I've never seen that clip either! Temp sensor plug is a rectangular one, like the ones that connect to the headlamps, etc, and plugs straight into the sensor.
danman2k
Thu Oct 23, 2008 10:31 pm
many thanks again, will get the car in good light with plenty time tomorrow and see. thanks :D
danman2k
Fri Oct 24, 2008 2:57 pm
cheers. i got the wire through the grommet and i found where to clip the sensor in. i have the same mounting clip for sensor as in the pic too 8O
