Deadlocks
Brenner5
Post Fri Jun 24, 2005 9:35 pm
i am assuming that these are standard on a 325i se, H plate
how do i get these to activate as when i press my alarm fob key the doors lock but the deadlocks don't
i have tested by leaving a window open and putting the alarm on, then open the door, the alarm comes on but the doors shouldn't open !!!
i have a sigma alrm too
320_Fizz_i
Martinaston
Post Fri Jun 24, 2005 9:45 pm
Do the deadlocks work with the key ?
Brenner5
Post Fri Jun 24, 2005 9:47 pm
i have tried locking the car with the key and left a window open and still the car doors open...
320_Fizz_i
Martinaston
Post Fri Jun 24, 2005 9:51 pm
Your deadlocks are buggerd if you have them
Brenner5
Post Fri Jun 24, 2005 9:53 pm
not good news :(
are deadlocks separtate from the actual locks so i can buy them
deadlocks are a must !!!!!!!!!
320_Fizz_i
Martinaston
Post Fri Jun 24, 2005 9:57 pm
Why are they a must if you have an alarm ?
Check some of the previous threads on how to fix them because i think Brianmoor will go mad if he has to explain it again.
Brenner5
Post Fri Jun 24, 2005 10:00 pm
i got a few amps/speakers etc so i want to make it as hard as possible for someone to break in, preparing for the worst if you know what i mean :)
will do a search now
cheers
320_Fizz_i
ian332isport
Brenner5 wrote:i have tried locking the car with the key and left a window open and still the car doors open...
Are you turning the key far enough to engage the dead locks ?
You need to turn the key 90 degrees anti clockwise and remove the key in that position to engage the deadlocks. Simply turning it to the 11 o'clock position will lock it, but not deadlock it.
Cheers,
Ian.
Martinaston
Post Fri Jun 24, 2005 10:03 pm
You must have unbreakable windows then :lol:
Brenner5
Post Fri Jun 24, 2005 10:22 pm
just checked now..
when i lock it at 90 degrees, only the drivers door opens, the other doors cant be opened from inside..
so the deadlocks do work apart from the drivers door.
when i use the key fob, the doors lock but not deadlocked.
is it normal that the drivers door can be opened whilst i am inside the car (while in deadlocks) or is that one not working??
320_Fizz_i
ian332isport
Post Fri Jun 24, 2005 10:35 pm
Brenner5 wrote:just checked now..
I don't believe it's possible to have remote deadlocks on an E30 (not using the standard setup anyhow).
I would need to check to be sure, but I would not expect you to be able to open the drivers door from the inside if deadlocked. It sounds like you have some sort of mechanical problem with the drivers door lock (it's a purely mechanical job on the drivers door).
Ian.
Brenner5
Post Fri Jun 24, 2005 10:41 pm
it does seem a bit silly if the drivers door can be opened while in deadlocks
i will play about a bit more tomorrow and if the drivers door don't stay locked i will change the mechanism and see how it goes
thanks for the quick and helpful replies :thumb:
320_Fizz_i
A1BMW325iSport
Post Fri Jun 24, 2005 10:44 pm
i agree with Ian totally
